[Swift-devel] Is there a site count limit?
    Michael Wilde
    wilde at mcs.anl.gov
    Wed Apr 15 07:47:02 CDT 2009
Yes, this would be very good. And at the same time review the rest of
the throttle parameters. I always have to scratch my head and re-read
the descriptions to get the behavior I want. If the other throttles asre
OK as-is, then it would still be good to clarify their explanations in
the properties file test and provide examples in the user guide.
On 4/15/09 4:25 AM, Ben Clifford wrote:
> On Fri, 10 Apr 2009, Mihael Hategan wrote:
>> Make the initial score larger. 10000 should be enough. As it goes to
>> +inf, you should have a max of 100*jobThrottle + 1 jobs.
> I would like to change the user interface for jobThrottle and initialScore
> to be much more human friendly - the present input numbers, whilst
> sufficiently expressive, are ridiculous from a normal user perspective.
> I would like to make a parameter to replace jobThrottle (either in CoG or
> in Swift) that you specify the actual maximum number of jobs
> (so that maxJobs = 100*jobThrottle +1)
> For initial score I would like to find some value range that is easier to
> understand for users - perhaps a fraction that indicates how many of
> the maxJobs the initialScore will start at.
