[Swift-devel] simple executable staging
    Ben Clifford
    benc at hawaga.org.uk
    Mon Apr 13 08:00:36 CDT 2009
You can do it now without too much hassle but its not as beautiful as it
could be. I thought I had added an example to the userguide but turns out
I haven't.
To do it now, make the analysis script an input data file and launch it
using /bin/sh (so /bin/sh is what does into the tc.data file, not your
actual application).
Some (?skenny) does similar stuff with a script Rinvoke (that is mapped in
tc.data) that launches R on an input script.
But I'd like that to look more elegant.
On Mon, 13 Apr 2009, Glen Hocky wrote:
> This could be potentially very useful for data analysis esp. if the analysis
> were performed with standard tools (e.g. perl, python, awk and gnuplot). If
> you could make simple changes to your analysis script and then push the data
> and analysis tools out for number crunching that would be great.
> Ben Clifford wrote:
> > I've seen enough simple (conceptually, not in run size) uses of Swift (2)
> > and heard enough from OSG Engage people about it being useful that I think
> > Swift should have an option to stage an executable instead of finding it
> > remotely.
> > This seems more useful in some fields and less so in others (for example,
> > where people are writing numeric code in C and so have few library
> > dependencies).
> > It can be done in Swift in a round-about way at the moment, but I think it
> > should be better supported.
> Swift-devel mailing list
> Swift-devel at ci.uchicago.edu
> http://mail.ci.uchicago.edu/mailman/listinfo/swift-devel
