[Swift-devel] Re: replication vs site score
    Ioan Raicu
    iraicu at cs.uchicago.edu
    Thu Apr  9 12:59:55 CDT 2009
Mihael Hategan wrote:
> On Thu, 2009-04-09 at 10:32 -0700, Ioan Raicu wrote:
>>  If not, then I'd say that dynamic resource provisioning has to be
>> kept at jobs of a single node level,
> That does not follow. The mutually-exclusive choices you are presenting
> are 1) no current support for block allocations, 2) single node
> allocations and you're missing 3) future support for block allocations.
> If (1) is false (2) is not the only alternative.
Remember, I said "if not", in other words, if Coaster does not support
this today, then (2) is your only alternative, unless you want to waste
many resources over time. Future support, obviously means that (2) will
not be the only alternative :)
Ioan Raicu, Ph.D.
Distributed Systems Laboratory
Computer Science Department
University of Chicago
1100 E. 58th Street, Ryerson Hall
Chicago, IL 60637
Email: iraicu at cs.uchicago.edu
Web:   http://www.cs.uchicago.edu/~iraicu
http://dev.globus.org/wiki/Incubator/Falkon
http://dsl-wiki.cs.uchicago.edu/index.php/Main_Page
URL: <http://lists.mcs.anl.gov/pipermail/swift-devel/attachments/20090409/ca37be93/attachment.html>
