[Swift-devel] [Bug 116] simple_mapper handling of numbered files in	arrays broken
    bugzilla-daemon at mcs.anl.gov
    Wed Apr  1 21:00:52 CDT 2009
https://bugzilla.mcs.anl.gov/swift/show_bug.cgi?id=116
Mihael Hategan <hategan at mcs.anl.gov> changed:
           What    |Removed                     |Added
                 CC|                            |hategan at mcs.anl.gov
--- Comment #3 from Mihael Hategan <hategan at mcs.anl.gov>  2009-04-01 21:00:52 ---
Additionally, if non-numerically named files exist (say "test.in"), simple
mapper tries to use that name as index, which may or may not be the right
thing, but it causes a consistency check failure on the array:
Execution failed:
    java.lang.RuntimeException: Array element has index 'test' that does not
parse as an integer.
Configure bugmail: https://bugzilla.mcs.anl.gov/swift/userprefs.cgi?tab=email
------- You are receiving this mail because: -------
You are on the CC list for the bug.
You are watching someone on the CC list of the bug.
You are watching the assignee of the bug.
You are watching the reporter.
