[Swift-devel] Re: swift 0.7rc1 - please test
Ben Clifford benc at hawaga.org.uk
Fri Oct 31 03:21:34 CDT 2008
I ran the site tests on 0.7rc1. Some stuff worked. Some stuff didn't. The
below failures don't bother me excessively for release, but I'll
investigate them more deeply.
These sites failed: fletch-condor-gram2.xml fletch-fork-gram2.xml
osg-edu.cs.wisc.edu-condor.xml tgncsa-hg-pbs-gram2.xml
tgncsa-hg-pbs-gram4.xml tgpurdue-condor-gram2.xml
tgpurdue-condor-gram4.xml tp-pbs-gram2.xml UCLA_Saxon_Tier3-fork.xml
These sites worked: osg-edu.cs.wisc.edu-fork.xml tgncsa-hg-fork-gram2.xml
tgncsa-hg-fork-gram4.xml tgpurdue-fork-gram2.xml tgpurdue-fork-gram4.xml
tgtacc-fork-gram2.xml tgtacc-lsf-gram2.xml tguc-fork-gram2.xml
tguc-fork-gram4.xml tguc-pbs-gram2-syntax1.xml tguc-pbs-gram2.xml
tguc-pbs-gram4.xml tp-fork-gram2.xml tp-fork-gram4.xml
