[Swift-devel] running 1 billion tasks through Falkon
Ioan Raicu iraicu at cs.uchicago.edu
Thu Oct 16 14:09:02 CDT 2008
Hi again,
Up to a few days ago, the largest test I ever did with Falkon, in terms
of number of tasks, was 20 million tasks, which worked as expected. For
the sake of pushing Falkon, perhaps to the point where it might break, I
tried the 20M task experiment again, but now with 1B (billion) tasks.
Note, this 1 billion tasks is from a single invocation of the Falkon
command line client.
On an orthogonal issue, I noticed that on simple sleep 0 tasks, I can't
seem to saturate my 8 CPU cores where I run the service, and usually, I
get 1~2 cores utilized. So, I decided to run 4 Falkon services on the
same machine, and use the load-balancing client (designed for the BG/P)
and ran 1B tasks (from another node with dual CPUs) across these 4
services (running on the 8-core node).  Each service managed 32 CPUs in
ANL/UC TG cluster, for a total of 128 CPUs, and each task was a simple
sleep 0, with no I/O.
Here is the plot of the run.
http://people.cs.uchicago.edu/~iraicu/projects/Falkon/plots/Falkon-1B-4serv-128cpu.jpg
The good news is that the test ran great, getting an average of 15558
tasks/sec. Now, the bad news is that the throughput seemed to drop from
17000 tasks/sec (at the beginning) to 15500 tasks/sec (at the end). The
explanation to the drop in throughput come from the memory management in
Java on the client side, which apparently was spending 5~10 seconds in
garbage collection every 60 seconds or so, and the amount of free heap
space was monotonically decreasing, on average.  See the graph
(http://people.cs.uchicago.edu/~iraicu/projects/Falkon/plots/Falkon-1B-4serv-128cpu-mem.jpg),
which shows the free heap size decreased down to around 200MB (from the
max of 1536MB). At the current rate of the potential memory leak I have
in the client, the free heap would get diminished to 0MB by 1.5 billion
tasks.
I just thought this was an interesting experiment, which revealed a
memory leak in the client, that did not show up in the smaller tests I
had done so far.
Cheers,
Ioan
Ioan Raicu
Ph.D. Candidate
Distributed Systems Laboratory
Computer Science Department
University of Chicago
1100 E. 58th Street, Ryerson Hall
Chicago, IL 60637
Email: iraicu at cs.uchicago.edu
Web:   http://www.cs.uchicago.edu/~iraicu
http://dev.globus.org/wiki/Incubator/Falkon
http://dsl-wiki.cs.uchicago.edu/index.php/Main_Page
