[Swift-devel]  swift builds on my machiens but not at nmi	build&test, with dependency problems
    Ben Clifford
    benc at hawaga.org.uk
    Wed Oct 15 17:53:17 CDT 2008
yep, the past few days of builds have not had this problem, it looks like.
On Mon, 13 Oct 2008, Mihael Hategan wrote:
> I made a commit today that should have fixed it.
> It was my attempt at automatically building coasters, which caused a
> circular dependency. It may work if you have a previous build.
> On Tue, 2008-10-14 at 04:02 +0000, Ben Clifford wrote:
> > When I run a build either on my laptop or communicado (my usual build
> > directory on my laptop, two separate fresh checkouts on communicado) I can
> > build ok.
> > When the nmi b&t machines run builds they have been failing since cog r
> > One example failure is here:
> > http://nmi-s005.cs.wisc.edu:80/nmi/index.php?page=results/runDetails&runid=109313&opt_project=swift
> > The output of my build is in
> > http://www.ci.uchicago.edu/~benc/tmp/depfail-benc.out
> > The output of the nmi build (in addition to being linked from the above
> > nmi-s005 link) is in
> > http://www.ci.uchicago.edu/~benc/tmp/depfail-nmi.out
> > A diff of those two is in
> > http://www.ci.uchicago.edu/~benc/tmp/depfail.diff
> > So it looks like in the nmi case, coasters are getting built before
> > karajan is attempted (or perhaps karajan is not attempted at all). In my
> > case, karajan is built first.
> > Not sure what is causing that.
