[Swift-devel]  swift builds on my machiens but not at nmi build&test, with dependency problems
    Ben Clifford
    benc at hawaga.org.uk
    Mon Oct 13 23:02:39 CDT 2008
When I run a build either on my laptop or communicado (my usual build
directory on my laptop, two separate fresh checkouts on communicado) I can
build ok.
When the nmi b&t machines run builds they have been failing since cog r
One example failure is here:
http://nmi-s005.cs.wisc.edu:80/nmi/index.php?page=results/runDetails&runid=109313&opt_project=swift
The output of my build is in
http://www.ci.uchicago.edu/~benc/tmp/depfail-benc.out
The output of the nmi build (in addition to being linked from the above
nmi-s005 link) is in
http://www.ci.uchicago.edu/~benc/tmp/depfail-nmi.out
A diff of those two is in
http://www.ci.uchicago.edu/~benc/tmp/depfail.diff
So it looks like in the nmi case, coasters are getting built before
karajan is attempted (or perhaps karajan is not attempted at all). In my
case, karajan is built first.
Not sure what is causing that.
