[Swift-devel] Re: swift guts doc with many diagrams and graphs
Ben Clifford benc at hawaga.org.uk
Mon Oct 13 20:23:24 CDT 2008
On Mon, 13 Oct 2008, Alina Bejan wrote:
> Please tell me if the instructions below are still accurate, or if anything
> changed -- basically the 'report-abc' directory  fails to being created.
Probably the thing to do is make a report to eithe r this or the users
list with the following: a URL or filesystem path where we can see the log
file; the output of running swoft-plot-log.
This guide isn't intended to contain basic user instructions for that -
the page that you looked at before (with the below instructions) is. Those
instructions that you pasted below should still work.
> "On a computer such as communicado, type:
>  svn co https://svn.ci.uchicago.edu/svn/vdl2/log-processing
>  cd log-processing/bin
>  export PATH=$(pwd):$PATH
>  swift-plot-log mylog-01234456-8922-abcdef.log
> This will give you a directory report-mylog-01234456-8922-abcdef/
> I usually then
> mv report-mylog-01234456-8922-abcdef ~benc/public_html/
> so that I can view it with a web browser at
> http://www.ci.uchicago.edu/~benc/report-mylog-01234456-8922-abcdef/
