[Swift-devel] lots of very small files vs gridftp
Ioan Raicu
iraicu at cs.uchicago.edu
Wed Oct 8 12:33:14 CDT 2008
No, the times included the time to allocate nodes as well, but that
wasn't really a significant part of those experiments due to the fact
that for the shorter experiments, we only used 8 to 32 nodes (probably
all got allocated in under 60 sec), and for the larger test, like
MolDyn, the tests lasted hours, so the several minutes it took to
allocate 200 processors was again not significant. In fact, in MolDyn,
you can actually see that only 150 or so processors were allocated
initially, and the rest up to the max of 216 processors were allocated
incrementally as they became available.
Ioan
Mihael Hategan wrote:
> On Mon, 2008-10-06 at 08:17 -0500, Ioan Raicu wrote:
>> We have plenty of application use cases. For example, section 5.4 in
>> http://people.cs.uchicago.edu/~iraicu/publications/2008_NOVA08_book-chapter_Swift.pdf,
> Were the falkon workers pre-allocated there?
Ioan Raicu
Ph.D. Candidate
Distributed Systems Laboratory
Computer Science Department
University of Chicago
1100 E. 58th Street, Ryerson Hall
Chicago, IL 60637
Email: iraicu at cs.uchicago.edu
Web: http://www.cs.uchicago.edu/~iraicu
http://dev.globus.org/wiki/Incubator/Falkon
http://dsl-wiki.cs.uchicago.edu/index.php/Main_Page
URL: <http://lists.mcs.anl.gov/pipermail/swift-devel/attachments/20081008/09dab672/attachment.html>
