[Swift-devel] Re: Thank you guys for the help
Zhao Zhang
zhaozhang at uchicago.edu
Fri Oct 3 13:57:50 CDT 2008
I was just trying to see if this is a problem, I put these two lines
back after my test.
zhao
Mihael Hategan wrote:
> So how do you clean up after the jobs?
> On Fri, 2008-10-03 at 13:50 -0500, Zhao Zhang wrote:
>> yep, I notice this also from the tests before. I was trying to shorten
>> this period of time
>> logstate "RM_JOBDIR"
>> #rm -rf "$DIR" 2>&1 >& "$INFO"
>> #checkError 254 "Failed to remove job directory $DIR"
>> logstate "TOUCH_SUCCESS"
>> As I comment the above 2 lines out, there was stilll a time gap between
>> these two time stamp.
>> zhao
>> Ben Clifford wrote:
>>> The wrapper log graph here shows not much time taken apart from the
>>> execution:
>>> http://www.ci.uchicago.edu/~zzhang/report-sleep-20081003-1246-hj5bau82/info.zeroed-trailsx.png
>>> The plot from your pre-patched version on 30th september:
>>> http://www.ci.uchicago.edu/~zzhang/report-sleep-20080930-2311-pn6sbed7/info.zeroed-trailsx.png
>>> looks like its spending a lot more time doing other stuff.
>>> It seems strange that changing the status file handling caused such a
>>> tightening of the other lines (representing time taken to do other
>>> wrapper.sh activities) on the graph, especially the times related to the
>>> jobdir handling (see previous message).
