[Swift-devel] could swift use return code from falkon as a success notification?
Zhao Zhang zhaozhang at uchicago.edu
Fri Oct 3 10:55:14 CDT 2008
I think it is from swift web page some time ago.
zhao
Mihael Hategan wrote:
> There are legitimate cases for setting the classpath. Not so much for
> SWIFT_HOME.
> Zhao, why do you set SWIFT_HOME?
> On Fri, 2008-10-03 at 11:27 +0000, Ben Clifford wrote:
>>> There you go. You have "." in you classpath, and you're running swift
>>> from ~/swift/etc which contains a bogus vdl-int.k
>> That's hit someone before, maybe Nika when she was trying to use falkon?
>>> 1. Swift/cog launchers using a pre-existing CLASSPATH has so far caused
>>> only problems and I have never heard of anybody having a legitimate use
>>> for this behavior (which may be because people don't complain if they
>>> don't have a problem). So I'm thinking of removing that. Any opinions?
>> I was thinking very similar about SWIFT_HOME yesterday, which similarly
>> appears to only have use in screwing up installations.
>> CLASSPATH would have use if people started trying to do link/run time
>> loading of interesting things, rather than compiling stuff into the source
>> directory. But that doesn't happen.
>> I think I'm happy with both of those being ignored from the calling
>> environment, or at least a stern warning being given or both.
