[Swift-devel] could swift use return code from falkon as a success notification?
Zhao Zhang
zhaozhang at uchicago.edu
Fri Oct 3 10:08:34 CDT 2008
Cool,
Remove everything doesn't solve the problem, but mv everything to
another dir does.
I am testing more about this for now, and will post the results. Thanks,
guys.
zhao
Mihael Hategan wrote:
> On Thu, 2008-10-02 at 23:48 -0500, Zhao Zhang wrote:
>> -rw-r--r-- 1 zzhang users 15372 2008-10-01 14:31 vdl-int.k
> There you go. You have "." in you classpath, and you're running swift
> from ~/swift/etc which contains a bogus vdl-int.k
> There are a few options for you:
> 1. Remove "." from CLASSPATH
> 1.a. Remove everything from CLASSPATH. At least when running Swift, you
> don't need anything there (unless you KNOW otherwise)
> 2. Run swift from another directory that does not contain some random
> vdl-int.k (or any other swift libraries)
> 3. Remove vdl-int.k from the etc directory
> And there is one option for me:
> 1. Swift/cog launchers using a pre-existing CLASSPATH has so far caused
> only problems and I have never heard of anybody having a legitimate use
> for this behavior (which may be because people don't complain if they
> don't have a problem). So I'm thinking of removing that. Any opinions?
