[Swift-devel] could swift use return code from falkon as	a	success	notification?
    Zhao Zhang
    zhaozhang at uchicago.edu
    Thu Oct  2 22:46:03 CDT 2008
zzhang at login6.surveyor:~> echo $SWIFT_HOME
/home/falkon/cog/modules/vdsk/dist/vdsk-svn/
zzhang at login6.surveyor:~> echo $CLASSPATH
.:/home/falkon/falkon/container:/home/falkon/falkon/container/build/classes:/home/falkon/falkon/container/lib/addressing-1.0.jar:/home/falkon/falkon/container/lib/axis.jar:/home/falkon/falkon/container/lib/axis-url.jar:/home/falkon/falkon/container/lib/bootstrap.jar:/home/falkon/falkon/container/lib/cog-axis.jar:/home/falkon/falkon/container/lib/cog-jglobus.jar:/home/falkon/falkon/container/lib/cog-tomcat.jar:/home/falkon/falkon/container/lib/cog-url.jar:/home/falkon/falkon/container/lib/commonj.jar:/home/falkon/falkon/container/lib/commons-beanutils.jar:/home/falkon/falkon/container/lib/commons-cli-2.0.jar:/home/falkon/falkon/container/lib/commons-collections-3.0.jar:/home/falkon/falkon/container/lib/commons-digester.jar:/home/falkon/falkon/container/lib/commons-discovery.jar:/home/falkon/falkon/container/lib/commons-logging.jar:/home/falkon/falkon/container/lib/concurrent.jar:/home/falkon/falkon/container/lib/cryptix32.jar:/home/falkon/falkon/container/lib/cryptix-asn1.jar:/home/falkon/falkon/container/lib/cryptix.jar:/home/falkon/falkon/container/lib/globus_delegation_service.jar:/home/falkon/falkon/container/lib/globus_delegation_stubs.jar:/home/falkon/falkon/container/lib/globus_usage_core.jar:/home/falkon/falkon/container/lib/globus_usage_packets_common.jar:/home/falkon/falkon/container/lib/globus_wsrf_mds_aggregator_stubs.jar:/home/falkon/falkon/container/lib/globus_wsrf_rendezvous_stubs.jar:/home/falkon/falkon/container/lib/globus_wsrf_rft_stubs.jar:/home/falkon/falkon/container/lib/globus_wsrf_tools_test.jar:/home/falkon/falkon/container/lib/gram-client.jar:/home/falkon/falkon/container/lib/gram-stubs.jar:/home/falkon/falkon/container/lib/gram-utils.jar:/home/falkon/falkon/container/lib/jaxrpc.jar:/home/falkon/falkon/container/lib/jce-jdk13-125.jar:/home/falkon/falkon/container/lib/jgss.jar:/home/falkon/falkon/container/lib/junit.jar:/home/falkon/falkon/container/lib/log4j-1.2.8.jar:/home/falkon/falkon/container/lib/naming-common.jar:/home/falkon/falkon/container/lib/naming-factory.jar:/home/falkon/falkon/container/lib/naming-java.jar:/home/falkon/falkon/container/lib/naming-resources.jar:/home/falkon/falkon/container/lib/nom_tam.jar:/home/falkon/falkon/container/lib/opensaml.jar:/home/falkon/falkon/container/lib/org_globus_GenericPortal_common.jar:/home/falkon/falkon/container/lib/org_globus_GenericPortal_services_core_WS.jar:/home/falkon/falkon/container/lib/org_globus_GenericPortal_services_core_WS_stubs.jar:/home/falkon/falkon/container/lib/puretls.jar:/home/falkon/falkon/container/lib/resolver.jar:/home/falkon/falkon/container/lib/saaj.jar:/home/falkon/falkon/container/lib/servlet.jar:/home/falkon/falkon/container/lib/swing-layout-1.0.jar:/home/falkon/falkon/container/lib/wsdl4j.jar:/home/falkon/falkon/container/lib/wsrf_common.jar:/home/falkon/falkon/container/lib/wsrf_core.jar:/home/falkon/falkon/container/lib/wsrf_core_registry.jar:/home/falkon/falkon/container/lib/wsrf_core_registry_stubs.jar:/home/falkon/falkon/container/lib/wsrf_core_samples_authzService.jar:/home/falkon/falkon/container/lib/wsrf_core_samples_authzService_stubs.jar:/home/falkon/falkon/container/lib/wsrf_core_samples_counter.jar:/home/falkon/falkon/container/lib/wsrf_core_samples_counter_stubs.jar:/home/falkon/falkon/container/lib/wsrf_core_samples_mgmt.jar:/home/falkon/falkon/container/lib/wsrf_core_samples_mgmt_stubs.jar:/home/falkon/falkon/container/lib/wsrf_core_stubs.jar:/home/falkon/falkon/container/lib/wsrf_mds_index_stubs.jar:/home/falkon/falkon/container/lib/wsrf_mds_usefulrp_schema_stubs.jar:/home/falkon/falkon/container/lib/wsrf_provider_jce.jar:/home/falkon/falkon/container/lib/wsrf_test_interop.jar:/home/falkon/falkon/container/lib/wsrf_test_interop_stubs.jar:/home/falkon/falkon/container/lib/wsrf_test.jar:/home/falkon/falkon/container/lib/wsrf_test_unit.jar:/home/falkon/falkon/container/lib/wsrf_test_unit_stubs.jar:/home/falkon/falkon/container/lib/wsrf_tools.jar:/home/falkon/falkon/container/lib/wss4j.jar:/home/falkon/falkon/container/lib/xalan.jar:/home/falkon/falkon/container/lib/xercesImpl.jar:/home/falkon/falkon/container/lib/xml-apis.jar:/home/falkon/falkon/container/lib/xmlsec.jar
zzhang at login6.surveyor:~> echo $PATH
/home/zzhang/xar/bin:/home/falkon/cog/modules/vdsk/dist/vdsk-svn//bin:/home/falkon/falkon/bin:/home/falkon/falkon/service:/home/falkon/falkon/worker:/home/falkon/falkon/client:/home/falkon/falkon/monitor:/home/falkon/falkon/webserver:/home/falkon/falkon/ploticus/src:/home/falkon/falkon/apache-ant-1.7.0:/home/falkon/falkon/apache-ant-1.7.0/bin:/usr/lib/jvm/java:/usr/lib/jvm/java/bin:/home/falkon/falkon/container:/home/falkon/falkon/container/bin:/bin:/usr/sbin:/etc:/usr/X11R6/bin:/usr/bin:/sbin:/usr/local/bin:/bgsys/drivers/ppcfloor/bin:/bgsys/drivers/ppcfloor/comm/bin:/dbhome/bgpdb2c/sqllib/lib:/opt/ibmcmp/vac/bg/9.0/bin:/opt/ibmcmp/vacpp/bg/9.0/bin:/opt/ibmcmp/xlf/bg/11.1/bin:/software/common/apps/mpiscripts:/software/common/apps/clusterbank-0.3.2/wrap:/software/common/apps/projects-list/bin:/home/zzhang/bin/linux-sles10-ppc64:/home/zzhang/bin:.:/software/common/apps/misc-scripts:/bgsys/drivers/ppcfloor/bin:/usr/lib/mit/bin:/usr/lib/mit/sbin
zzhang at login6.surveyor:~/swift/etc> swift -sites.file ./sites.xml
-tc.file ./tc.data sleep.swift
Swift svn swift-r2249 (Swift modified locally) cog-r2216
RunID: 20081002-2244-4274vop7
Failed to transfer wrapper log from
sleep-20081002-2244-4274vop7/info/r/e/bgp0
sleep-20081002-2244-4274vop7/info/3/f/bgp0
sleep-20081002-2244-4274vop7/info/z/c/bgp0
Sorted: [bgp0:619.143(97.660):254/782 overload: 0]
zhao
