[Swift-devel] could swift use return code from falkon as a success notification?
Zhao Zhang
zhaozhang at uchicago.edu
Thu Oct 2 21:55:36 CDT 2008
oops, the log is at
http://www.ci.uchicago.edu/~zzhang/sleep-20081002-2151-53sor77c.log
<http://www.ci.uchicago.edu/%7Ezzhang/sleep-20081002-2151-53sor77c.log>
Zhao Zhang wrote:
> yep, I use the same linux session, get an allocation of 64 CN on BGP.
> still get the same error
> Failed to transfer wrapper log from
> sleep-20081002-2151-53sor77c/info/7/m/bgp0
> sleep-20081002-2151-53sor77c/info/a/l/bgp0
> sleep-20081002-2151-53sor77c/info/q/l/bgp0
> sleep-20081002-2151-53sor77c/info/o/l/bgp0
> sleep-20081002-2151-53sor77c/info/f/m/bgp0
> sleep-20081002-2151-53sor77c/info/4/m/bgp0
> Sorted: [bgp0:35.918(66.664):208/534 overload: 0]
> Sorted: [bgp0:35.918(66.664):209/534 overload: 0]
> Sorted: [bgp0:35.818(66.590):209/533 overload: 0]
> Sorted: [bgp0:35.818(66.590):210/533 overload: 0]
> Sorted: [bgp0:35.818(66.590):211/533 overload: 0]
> sleep-20081002-2151-53sor77c/info/m/l/bgp0
> Progress: Stage in:1 Submitted:244 Failed but can retry:11
> Sorted: [bgp0:34.918(65.904):212/528 overload: 0]
> sleep-20081002-2151-53sor77c/info/1/l/bgp0
> sleep-20081002-2151-53sor77c/info/u/k/bgp0
> sleep-20081002-2151-53sor77c/info/e/l/bgp0
> sleep-20081002-2151-53sor77c/info/2/l/bgp0
> Sorted: [bgp0:33.426(64.706):210/518 overload: 0]
> sleep-20081002-2151-53sor77c/info/9/l/bgp0
> Sorted: [bgp0:33.529(64.791):210/519 overload: 0]
> Sorted: [bgp0:33.529(64.791):211/519 overload: 0]
> Sorted: [bgp0:33.334(64.629):210/518 overload: 0]
> Sorted: [bgp0:33.334(64.629):211/518 overload: 0]
> Sorted: [bgp0:33.334(64.629):212/518 overload: 0]
> Waiting for notification for 0 ms
> Received notification with 1 messages
> Progress: Submitted:255 Active:1
> sleep-20081002-2151-53sor77c/info/t/m/bgp0
> sleep-20081002-2151-53sor77c/info/v/m/bgp0
> sleep failed
> sleep failed
> Execution failed:
> Exception in sleep:
> Arguments: [30]
> Host: bgp0
> Directory: sleep-20081002-2151-53sor77c/jobs/t/m/sleep-tms9ka0j
> stderr.txt:
> stdout.txt:
> Caused by:
> No status file was found. Check the shared filesystem on bgp0
> zhao
> Mihael Hategan wrote:
>> Now do the exact same thing (that means everything Ben said), but
>> instead of "swift /home/falkon/cog/module/vdsk/examples/first.swift"
>> run "swift -sites.file ./sites.xml -tc.file ./tc.data sleep.swift"
