[Swift-devel] could swift use return code from falkon as a success notification?
Zhao Zhang zhaozhang at uchicago.edu
Thu Oct 2 19:49:09 CDT 2008
echo $CLASSPATH
zzhang at login6.surveyor:/home/falkon/cog/modules/vdsk/dist/vdsk-svn/examples/vdsk>
echo $CLASSPATH
.:/home/falkon/falkon/container:/home/falkon/falkon/container/build/classes:/home/falkon/falkon/container/lib/addressing-1.0.jar:/home/falkon/falkon/container/lib/axis.jar:/home/falkon/falkon/container/lib/axis-url.jar:/home/falkon/falkon/container/lib/bootstrap.jar:/home/falkon/falkon/container/lib/cog-axis.jar:/home/falkon/falkon/container/lib/cog-jglobus.jar:/home/falkon/falkon/container/lib/cog-tomcat.jar:/home/falkon/falkon/container/lib/cog-url.jar:/home/falkon/falkon/container/lib/commonj.jar:/home/falkon/falkon/container/lib/commons-beanutils.jar:/home/falkon/falkon/container/lib/commons-cli-2.0.jar:/home/falkon/falkon/container/lib/commons-collections-3.0.jar:/home/falkon/falkon/container/lib/commons-digester.jar:/home/falkon/falkon/container/lib/commons-discovery.jar:/home/falkon/falkon/container/lib/commons-logging.jar:/home/falkon/falkon/container/lib/concurrent.jar:/home/falkon/falkon/container/lib/cryptix32.jar:/home/falkon/falkon/container/lib/cryptix-asn1.jar:/home/falkon/falkon/container/lib/cryptix.jar:/home/falkon/falkon/container/lib/globus_delegation_service.jar:/home/falkon/falkon/container/lib/globus_delegation_stubs.jar:/home/falkon/falkon/container/lib/globus_usage_core.jar:/home/falkon/falkon/container/lib/globus_usage_packets_common.jar:/home/falkon/falkon/container/lib/globus_wsrf_mds_aggregator_stubs.jar:/home/falkon/falkon/container/lib/globus_wsrf_rendezvous_stubs.jar:/home/falkon/falkon/container/lib/globus_wsrf_rft_stubs.jar:/home/falkon/falkon/container/lib/globus_wsrf_tools_test.jar:/home/falkon/falkon/container/lib/gram-client.jar:/home/falkon/falkon/container/lib/gram-stubs.jar:/home/falkon/falkon/container/lib/gram-utils.jar:/home/falkon/falkon/container/lib/jaxrpc.jar:/home/falkon/falkon/container/lib/jce-jdk13-125.jar:/home/falkon/falkon/container/lib/jgss.jar:/home/falkon/falkon/container/lib/junit.jar:/home/falkon/falkon/container/lib/log4j-1.2.8.jar:/home/falkon/falkon/container/lib/naming-common.jar:/home/falkon/falkon/container/lib/naming-factory.jar:/home/falkon/falkon/container/lib/naming-java.jar:/home/falkon/falkon/container/lib/naming-resources.jar:/home/falkon/falkon/container/lib/nom_tam.jar:/home/falkon/falkon/container/lib/opensaml.jar:/home/falkon/falkon/container/lib/org_globus_GenericPortal_common.jar:/home/falkon/falkon/container/lib/org_globus_GenericPortal_services_core_WS.jar:/home/falkon/falkon/container/lib/org_globus_GenericPortal_services_core_WS_stubs.jar:/home/falkon/falkon/container/lib/puretls.jar:/home/falkon/falkon/container/lib/resolver.jar:/home/falkon/falkon/container/lib/saaj.jar:/home/falkon/falkon/container/lib/servlet.jar:/home/falkon/falkon/container/lib/swing-layout-1.0.jar:/home/falkon/falkon/container/lib/wsdl4j.jar:/home/falkon/falkon/container/lib/wsrf_common.jar:/home/falkon/falkon/container/lib/wsrf_core.jar:/home/falkon/falkon/container/lib/wsrf_core_registry.jar:/home/falkon/falkon/container/lib/wsrf_core_registry_stubs.jar:/home/falkon/falkon/container/lib/wsrf_core_samples_authzService.jar:/home/falkon/falkon/container/lib/wsrf_core_samples_authzService_stubs.jar:/home/falkon/falkon/container/lib/wsrf_core_samples_counter.jar:/home/falkon/falkon/container/lib/wsrf_core_samples_counter_stubs.jar:/home/falkon/falkon/container/lib/wsrf_core_samples_mgmt.jar:/home/falkon/falkon/container/lib/wsrf_core_samples_mgmt_stubs.jar:/home/falkon/falkon/container/lib/wsrf_core_stubs.jar:/home/falkon/falkon/container/lib/wsrf_mds_index_stubs.jar:/home/falkon/falkon/container/lib/wsrf_mds_usefulrp_schema_stubs.jar:/home/falkon/falkon/container/lib/wsrf_provider_jce.jar:/home/falkon/falkon/container/lib/wsrf_test_interop.jar:/home/falkon/falkon/container/lib/wsrf_test_interop_stubs.jar:/home/falkon/falkon/container/lib/wsrf_test.jar:/home/falkon/falkon/container/lib/wsrf_test_unit.jar:/home/falkon/falkon/container/lib/wsrf_test_unit_stubs.jar:/home/falkon/falkon/container/lib/wsrf_tools.jar:/home/falkon/falkon/container/lib/wss4j.jar:/home/falkon/falkon/container/lib/xalan.jar:/home/falkon/falkon/container/lib/xercesImpl.jar:/home/falkon/falkon/container/lib/xml-apis.jar:/home/falkon/falkon/container/lib/xmlsec.jar
echo $SWIFT_HOME
echo $SWIFT_HOME
Ben Clifford wrote:
> In one shell session type all the commands that Mihael told you to type,
> also:
> echo $PATH
echo $PATH
/home/zzhang/xar/bin:/home/falkon/cog/modules/vdsk/dist/vdsk-svn//bin:/home/falkon/falkon/bin:/home/falkon/falkon/service:/home/falkon/falkon/worker:/home/falkon/falkon/client:/home/falkon/falkon/monitor:/home/falkon/falkon/webserver:/home/falkon/falkon/ploticus/src:/home/falkon/falkon/apache-ant-1.7.0:/home/falkon/falkon/apache-ant-1.7.0/bin:/usr/lib/jvm/java:/usr/lib/jvm/java/bin:/home/falkon/falkon/container:/home/falkon/falkon/container/bin:/bin:/usr/sbin:/etc:/usr/X11R6/bin:/usr/bin:/sbin:/usr/local/bin:/bgsys/drivers/ppcfloor/bin:/bgsys/drivers/ppcfloor/comm/bin:/dbhome/bgpdb2c/sqllib/lib:/opt/ibmcmp/vac/bg/9.0/bin:/opt/ibmcmp/vacpp/bg/9.0/bin:/opt/ibmcmp/xlf/bg/11.1/bin:/software/common/apps/mpiscripts:/software/common/apps/clusterbank-0.3.2/wrap:/software/common/apps/projects-list/bin:/home/zzhang/bin/linux-sles10-ppc64:/home/zzhang/bin:.:/software/common/apps/misc-scripts:/bgsys/drivers/ppcfloor/bin:/usr/lib/mit/bin:/usr/lib/mit/sbin
> and:
> swift /home/falkon/cog/module/vdsk/examples/first.swift
swift first.swift
Swift svn swift-r2249 (Swift modified locally) cog-r2216
RunID: 20081002-1944-9o23gci1
Progress:
echo started
Sorted: [localhost:0.000(1.000):0/1 overload: 0]
echo completed
Final status:  Finished successfully:1
the log file is at
http://www.ci.uchicago.edu/~zzhang/first-20081002-1944-9o23gci1.log
<http://www.ci.uchicago.edu/%7Ezzhang/first-20081002-1944-9o23gci1.log>
zhao
> and paste the entire shell session into an email without deleting
> anything, without closing any window, without even changing to a
> different window or getting up to get a drink or anything else at all.
