[Swift-devel] karajan futures and getfieldvalue/setfieldvalue
Ben Clifford
benc at hawaga.org.uk
Sun Nov 16 01:37:12 CST 2008
While playing round with how setfieldvalue works, I came across the
following; I don't understand enough about how karajan deals / is meant to
deal with futures to see what is going on.
The attached attach, error.patch, is intended to amend the behaviour of
Swift HEAD so that getFieldValue is not used to get an unwrapped
(not-in-DSHandle) value to pass into SetFieldValue.
The attached patch test.patch contains a test, test.swift, which appears
to work repeatedly on swift/cog HEAD but fails often on my laptop with
error.patch applied (although sometimes works).
Changing the number of assignment steps in test.swift changes the
likelihood that the execution will fail - more steps = higher probability
of failure (which makes sense as there is a race to get the circumstances
that trigger this).
It looks like if SetFieldValue throws a FutureNotYetAvailable exception,
then this does not have the same behaviour of deferring execution and
rerunning later, as when GetFieldValue throws a FutureNotAvailable
exception which seems to work ok.
There is an execution log for a failed log at
http://www.ci.uchicago.edu/~benc/test-20081116-0133-vr84izb8.log
(btw When running this test on two different versions, don't forget to
force a recompile: touch test.swift && swift test.swift)
Type: text/x-diff
Desc:
URL: <http://lists.mcs.anl.gov/pipermail/swift-devel/attachments/20081116/50e30a72/attachment.patch>
Type: text/x-diff
Desc:
URL: <http://lists.mcs.anl.gov/pipermail/swift-devel/attachments/20081116/50e30a72/attachment-0001.patch>
