[Swift-devel] exception report
Zhao Zhang
zhaozhang at uchicago.edu
Fri Nov 14 13:07:26 CST 2008
Hi, Sorry for the late response, the source code is here:
http://www.ci.uchicago.edu/~zzhang/dock3.swift
And yes, my other swift scripts work well.
zhao
Ben Clifford wrote:
> Hmm. Can you send the source code for your SwiftScript?
> I think you might be running into the 'data dependency vs sequential
> execution' problem that I've been working to fix recently. But I'd lke to
> see your source code.
> On Thu, 13 Nov 2008, Zhao Zhang wrote:
>> Hi, All
>> I got an exception for the swift script on BGP, although it returned
>> successful.
>> The log file is at
>> http://www.ci.uchicago.edu/~zzhang/dock3-20081113-1707-j38zbyp9.log
>> The swift script is at http://www.ci.uchicago.edu/~zzhang/dock3.swift
>> zhao
>> zzhang at login6.surveyor:~/swift/test> ./run_swift.sh 0754 64 dock3.swift `pwd`
>> waiting for at least 64 nodes to register before submitting workload...
>> waiting to find at least 1 services in file
>> /home/falkon/users/zzhang/0754/config/Client-service-URIs.config...
>> all done, file has found at least 1 services
>> found at least 64 registered, submitting workload...
>> Swift svn swift-r2249 (Swift modified locally) cog-r2216
>> RunID: 20081113-1707-j38zbyp9
>> Progress:
>> org.griphyn.vdl.karajan.VDL2FutureException
>> at
>> org.griphyn.vdl.mapping.MappingParam.checkHandle(MappingParam.java:74)
>> at org.griphyn.vdl.mapping.MappingParam.getValue(MappingParam.java:46)
>> at
>> org.griphyn.vdl.mapping.MappingParam.getStringValue(MappingParam.java:82)
>> at
>> org.griphyn.vdl.mapping.file.SingleFileMapper.existing(SingleFileMapper.java:24)
>> at
>> org.griphyn.vdl.mapping.RootDataNode.checkInputs(RootDataNode.java:67)
>> at
>> org.griphyn.vdl.mapping.RootDataNode.checkInputs(RootDataNode.java:48)
>> at org.griphyn.vdl.mapping.RootDataNode.init(RootDataNode.java:38)
>> at org.griphyn.vdl.karajan.lib.New.function(New.java:127)
>> at org.griphyn.vdl.karajan.lib.VDLFunction.post(VDLFunction.java:65)
>> at
>> org.globus.cog.karajan.workflow.nodes.AbstractSequentialWithArguments.childCompleted(AbstractSequentialWithArguments.java(Compiled
>> Code))
>> at
>> org.globus.cog.karajan.workflow.nodes.Sequential.notificationEvent(Sequential.java(Compiled
>> Code))
>> at
>> org.globus.cog.karajan.workflow.nodes.FlowNode.event(FlowNode.java(Compiled
>> Code))
>> at
>> org.globus.cog.karajan.workflow.events.EventBus.send(EventBus.java(Compiled
>> Code))
>> at
>> org.globus.cog.karajan.workflow.events.EventBus.sendHooked(EventBus.java(Compiled
>> Code))
>> at
>> org.globus.cog.karajan.workflow.nodes.FlowNode.fireNotificationEvent(FlowNode.java(Compiled
>> Code))
>> at
>> org.globus.cog.karajan.workflow.nodes.FlowNode.complete(FlowNode.java(Inlined
>> Compiled Code))
>> at
>> org.globus.cog.karajan.workflow.nodes.FlowContainer.post(FlowContainer.java(Compiled
>> Code))
>> at
>> Code))
>> at
>> org.globus.cog.karajan.workflow.nodes.user.UserDefinedElement.childCompleted(UserDefinedElement.java:283)
>> at
>> org.globus.cog.karajan.workflow.nodes.user.SequentialImplicitExecutionUDE.childCompleted(SequentialImplicitExecutionUDE.java:85)
>> at
>> Code))
>> at
>> Code))
>> at
>> Code))
>> at
>> Code))
>> at
>> Code))
>> at
>> Compiled Code))
>> at
>> Code))
>> at
>> org.globus.cog.karajan.workflow.nodes.functions.Argument.post(Argument.java:45)
>> at
>> Code))
>> at
>> Code))
>> at
>> Code))
>> at
>> Code))
>> at
>> Code))
>> at
>> Code))
>> at
>> Compiled Code))
>> at
>> Code))
>> at
>> org.globus.cog.karajan.workflow.nodes.functions.Map_Map.post(Map_Map.java:55)
>> at
>> org.globus.cog.karajan.workflow.nodes.Sequential.startNext(Sequential.java(Compiled
>> Code))
>> at
>> org.globus.cog.karajan.workflow.nodes.Sequential.childCompleted(Sequential.java:45)
>> at
>> Code))
>> at
>> Code))
>> at
>> Code))
>> at
>> Code))
>> at
>> Code))
>> at
>> Compiled Code))
>> at
>> Code))
>> at org.globus.cog.karajan.workflow.nodes.Each.post(Each.java:31)
>> at
>> Code))
>> at
>> Code))
>> at
>> Code))
>> at
>> Code))
>> at
>> Code))
>> at
>> Code))
>> at
>> Compiled Code))
>> at
>> Code))
>> at
>> org.globus.cog.karajan.workflow.nodes.functions.AbstractFunction.post(AbstractFunction.java:46)
>> at
>> Code))
>> at
>> org.globus.cog.karajan.workflow.nodes.Sequential.executeChildren(Sequential.java(Compiled
>> Code))
>> at
>> org.globus.cog.karajan.workflow.nodes.functions.AbstractFunction.executeChildren(AbstractFunction.java:40)
>> at
>> org.globus.cog.karajan.workflow.nodes.FlowContainer.execute(FlowContainer.java(Compiled
>> Code))
>> at
>> org.globus.cog.karajan.workflow.nodes.FlowNode.restart(FlowNode.java(Compiled
>> Code))
>> at
>> org.globus.cog.karajan.workflow.nodes.FlowNode.start(FlowNode.java(Inlined
>> Compiled Code))
>> at
>> org.globus.cog.karajan.workflow.nodes.FlowNode.controlEvent(FlowNode.java(Compiled
>> Code))
>> at
>> Code))
>> at
>> org.globus.cog.karajan.workflow.FlowElementWrapper.event(FlowElementWrapper.java(Compiled
>> Code))
>> at
>> Code))
>> at
>> Code))
>> at
>> org.globus.cog.karajan.workflow.events.EventWorker.run(EventWorker.java:69)
>> Swift-devel mailing list
>> Swift-devel at ci.uchicago.edu
>> http://mail.ci.uchicago.edu/mailman/listinfo/swift-devel
