[Swift-devel] exception report
Ben Clifford
benc at hawaga.org.uk
Fri Nov 14 11:06:09 CST 2008
On Thu, 13 Nov 2008, Zhao Zhang wrote:
> Nothing new to the the data logic. All swift scripts which were working before
> are still working, we are just trying a new swfit script out.
Here is a useful debugging technique:
Symptoms:
I changed X and only X.
Now A is broken.
action: change X back to what it was before and see if A is broken.
That's a very basic way of determining if the changes you made caused the
problem.
In your case, you claim that the only change is trying to run a new
swiftscript.
So if you run an old swiftscript that worked a day or so ago, what
happens? Do you get the error or not?
When reporting problems, its useful to try things like this first, and
include the information about where X really does afffect A in your
problem report email.
It makes it a lot easier for other people to think about narrowing down
the problem.
