[Swift-devel] discussion for swift output file path
Zhao Zhang
zhaozhang at uchicago.edu
Thu Nov 13 12:40:31 CST 2008
Ben Clifford wrote:
> On Thu, 6 Nov 2008, Zhao Zhang wrote:
>> I am working on integrate the Collective IO system and swift on BGP. Before
>> that, for the purpose of put swift into production work,
> It would be useful if the changes, if they're useful, end up in the
> production Swift SVN - keeping everyone's codebase fairly tightly
> converged seems a good thing to me.
> Points 1 and 3 below seem more difficult, but point 2:
>> 2. change wrapper.sh: copy files from local ramdisck to GPFS using dd
>> instead of cp, straghtforward.
> is easy to put in. Is there a measurable performance increase using dd
> rather than cp? And dd using default block size or different ones?
yep, I made this working on surveyor. cp on CN uses a lined-buffer for
output, thus a bad performance. the suggested block size of dd from
Kamil is 128KB.
zhao
>> 1. change vdl-int.k: create hierarchical directory in shared/,
>> straightforward
>> 3. change somewhere in swift to make swift know where the data is, the path of
>> the output file in jobdir/shared/ unknown
