[Swift-devel] discussion for swift output file path
Zhao Zhang zhaozhang at uchicago.edu
Thu Nov 13 00:08:28 CST 2008
Hi, Ben
Are you working at CI tomorrow? I mean Thursday. So we could work
together to make this working.
zhao
Ben Clifford wrote:
> The wrapper does not necessarily put all output files in one directory.
> It puts them in a directory structure reflecting the submit-side directory
> structure. For example, if you map a file "a/b", it will end up in the
> shared directory as shared/a/b
> This is exposed to the user, though, rather than being hidden as with the
> other uses of subdirectories.
> There are a few places throughout the source code where its assumed that
> the path locally and remote path are basically the same (modulo base
> directory). I think its probably fairly straightforward to make it use
> different names, thoughLook for lines in vdl-int.k that look like this:
>     task:transfer(srcprovider=provider,
> srchost=srchost, srcfile=filename,
>                                                 srcdir=srcdir,
> desthost=host, destdir=destdir)
> You can put a different destdir in there, based on (for example) some hash
> of the filename. Simialrly hash the filenames when they are passed as
> inputs to wrapper.sh in the vdl:execute line in vdl-int.k
> On Thu, 6 Nov 2008, Zhao Zhang wrote:
>> Hi, All
>> I am working on integrate the Collective IO system and swift on BGP. Before
>> that, for the purpose of put swift into production work,
>> we need to change the output file path. For now, wrapper.sh would copy all
>> output files to jobdir/shared/, on BGP, all output files will
>> be written to one directory, which I am sure will cause the GPFS lock
>> mechanism, thus introduce unacceptable latency.
>> So the easiest way to fix this is "make a hierarchical directory in shared/
>> and we already did in info/ and jobs/". Several changes we need:
>>     place-need-change
>> diffculty
>> 1. change vdl-int.k: create hierarchical directory in shared/,
>> straightforward
>> 2. change wrapper.sh: copy files from local ramdisck to GPFS using dd instead
>> of cp,      straghtforward.
>> 3. change somewhere in swift to make swift know where the data is, the path of
>> the output file in jobdir/shared/    unknown
>> Any comments will be appreciated.
>> best wishes
>> zhangzhao
>> Swift-devel mailing list
>> Swift-devel at ci.uchicago.edu
>> http://mail.ci.uchicago.edu/mailman/listinfo/swift-devel
