[Swift-devel] discussion for swift output file path
Ben Clifford benc at hawaga.org.uk
Thu Nov 6 19:23:44 CST 2008
On Thu, 6 Nov 2008, Mihael Hategan wrote:
> Only if we assume non-reentrant read locks. And this would need some
> investigation, but if concurrent reads do not create contention, then
> there is no problem, because once a job is done, there is no more
> writing to its directory.
If job output files are left in their job directory, rather than put in
some hashed-by-filename shared directory, I think that is true. Otherwise,
the access patterns for any given hash bucket for a hash-on-filename are
going to be fairly random, with reads and writes happening at all sorts of
different times and from many different places.
Keeping output files in job-specific directories seems a reasonable thing
to do performance wise, but means more awareness on the submit side about
which files came from which job.
