[Swift-devel] 0.7rc1 + local coasters + communicado
Ben Clifford
benc at hawaga.org.uk
Wed Nov 5 14:36:49 CST 2008
The below one-liner seems to fix hanging on my laptop. I didn't commit in
case I'm missing something in the logic, but I think its ok:
src/org/globus/cog/abstraction/impl/execution/local/JobSubmissionTaskHandler.java
(revision 2257)
(working copy)
@@ -342,6 +342,7 @@
boolean any = processPairs();
if (processDone()) {
closePairs();
+ return;
else {
if (!any)
Also, though I don't see that it would cause a lock, this looks wrong:
int avail = sp.is.available();
if (avail > 0) {
any = true;
int len = sp.is.read();
sp.os.write(buf, 0, len);
InputStream.read() with no parameter returns the read byte, not a buffer
length. read(buf, offset, len) is perhaps what is intended - I think at
present its going to send out big wads of empty space instead of stream
content.
Also, I was wrong about it passing on the nmi buid and test system - that
test is still queued to run at the moment.
