[Swift-devel] Re: [Swift-user] Swift finished with errors
Ben Clifford benc at hawaga.org.uk
Fri May 30 06:56:46 CDT 2008
> Replication v2 is in:
> cog r2031
> swift r2038
> This one hopefully properly deals with throttling.
062-two-in-a-row.swift itself runs without exiting with failure.
However, it does not appear to do the stageout for the second job -
running it with:
./run 062-two-in-a-row.swift
gives a test failure because of that.
Changing:
    <execution provider="wonky" />
to
    <execution provider="local" />
makes this work, and changing it back makes it not work.
I put a copy of the log in
http://www.ci.uchicago.edu/~benc/tmp/062-two-in-a-row-20080530-1248-v44k1kg2.log
