[Swift-devel] failure reporting
Mihael Hategan hategan at mcs.anl.gov
Thu May 29 19:51:35 CDT 2008
On Fri, 2008-05-30 at 00:46 +0000, Ben Clifford wrote:
> On Thu, 29 May 2008, Mihael Hategan wrote:
> > It's there, so unless that last catch block doesn't execute
> I think that is exactly what is happening.
> If I do this (which is presumably the wrong thing for replication, but
> otherwise I think ok):
> -                                       catch("^(?!Abort)$"
Now that you mention it, I might only have tested that regexp in perl.
Back to the drawing board.
> +                                       catch(".*"
>                                                 vdl:setprogress("Failed
> but can retry")
>                                                 log(LOG:DEBUG,
> "APPLICATION_EXCEPTION jobid={jobid} - Application exception: ",
> exception)
> then I get the logging back.
