[Swift-devel] Re: [Swift-user] Swift finished with errors
    Mihael Hategan
    hategan at mcs.anl.gov
    Thu May 29 12:30:05 CDT 2008
On Thu, 2008-05-29 at 17:24 +0000, Ben Clifford wrote:
> On Thu, 29 May 2008, Mihael Hategan wrote:
> > <     <profile namespace="karajan" key="jobThrottle">0</profile>
> > Though that also seems to beg the question: why is that a default?
> That line is a default on the local site because local sites tend to run
> with provider local onto ~2 CPU cores with no LRM management of load.
> Other site definitions (in the default sites.xml file and in for example
> tests/sites/) don't use that setting, so that they pick up the
> usually-appropriate-for-GRAM2 setting of 0.2 from swift.properties.
That makes sense. Though not for wonky.
