[Swift-devel] external datasets
    Ben Clifford
    benc at hawaga.org.uk
    Tue May 27 17:46:24 CDT 2008
Someone (that I don't remember - probably mike (wilde) or mihael)
requested (in person) a way of expressing dependencies between procedures
that doesn't involve making a dummy data file.
I have a prototype implementation that lets you do this. An example is
below. There is a new type called "external". Variables of "external" type
are not mapped to any file, but they participate in dependency ordering
with an external value acting as if it has been assigned when it is
returned from a procedure.
Running the below code will cause echo to run, and then ls to run only
when echo has finished.
The name "external" comes from a conceptualisation of this as representing
some data that is stored externally to Swift - instead of being mapped
with a mapping expression, with Swift handling stage-in and stage-out etc,
the data is external and its up to your apps to deal with access to
whatever the data is.
Be cautious using this in the presence of retries, replication, and
restarts (the 3 Rs?) - Swift won't provide any of the handling for
external data that it provides for output files.
(external db) first() {
app {
  echo;
second(external db) {
app {
  ls;
external o;
second(o);
o=first();
