[Swift-devel] Re: [Swift-user] what is wrong with restart5.swift?
Ben Clifford
benc at hawaga.org.uk
Tue May 27 16:07:56 CDT 2008
On Tue, 27 May 2008, Mihael Hategan wrote:
> The concurrent mapper still uses the run id as part of the path in which
> it puts files. That has yet to be addressed.
It uses an ID that is put in at compile time.
Restarting works with the concurrent mapper unless you've touched the
source file (in which case, it seems reasonable (to me) that restarts are
ignored, and probably should be more enforced, irrespective of whether the
concurrent mapper is used or not)
