[Swift-devel] [Bug 142] New: concurrent mapper does not work when	used inside iterate {} block
    bugzilla-daemon at mcs.anl.gov
    Sun May 25 19:02:34 CDT 2008
http://bugzilla.mcs.anl.gov/swift/show_bug.cgi?id=142
           Summary: concurrent mapper does not work when used inside iterate
                    {} block
           Product: Swift
           Version: unspecified
          Platform: Macintosh
        OS/Version: Mac OS
            Status: NEW
          Severity: normal
          Priority: P2
         Component: SwiftScript language
        AssignedTo: benc at hawaga.org.uk
        ReportedBy: benc at hawaga.org.uk
                CC: swift-devel at ci.uchicago.edu
concurrent mapper does not work when used inside an iterate {} block. This
happens:
Execution failed:
        java.lang.Integer
Caused by:
        java.lang.ClassCastException: java.lang.Integer
        at
org.griphyn.vdl.karajan.lib.VDLFunction.getThreadPrefix(VDLFunction.java:117)
        at org.griphyn.vdl.karajan.lib.New.function(New.java:65)
        at org.griphyn.vdl.karajan.lib.VDLFunction.post(VDLFunction.java:65)
getThreadPrefix expects the $ variable in a karajan stack frame, if defined, to
be a list where the first element is an iteration number; that is not the case
with iterate.
Configure bugmail: http://bugzilla.mcs.anl.gov/swift/userprefs.cgi?tab=email
------- You are receiving this mail because: -------
You are on the CC list for the bug, or are watching someone who is.
