[Swift-devel] testing replication
    Ben Clifford
    benc at hawaga.org.uk
    Thu May 22 07:48:47 CDT 2008
I was motivated to build a test framework for replication, and through it
I have recreated (in exciting repeatable fashion) what superficially
appears to be a problem that Xi Li encountered the other day.
I hacked (in racy, unundented glory) provider-local to be sometimes slow
(where sometimes means 2 minute delay on every execution except the
first). This is provider-wonky, which is in
https://svn.ci.uchicago.edu/svn/vdl2/provider-wonky.
Add a dependency for provider-wonky and build Swift.
Set provider="wonky" for execution in sites.xml, instead of local
provider.
Attempt to run test 062-two-in-a-row. Observe that it runs (with the first
job finishing pretty much instantly, and the second job taking a couple of
minutes).
Activate replication with:
replication.enabled=true
replication.min.queue.time=15
Attempt to run 062-to-in-a-row again. Observe that the workflow does not
finish successfully (and that, at least superficially, it looks like the
same problem Xi had).
This is what I see on my console (it takes about 10 minutes to run in
total):
Swift svn swift-r1990 (Swift modified locally) cog-r2023 (CoG modified
locally)
RunID: 20080522-1339-sygzk6qc
Progress:
echo started
Submitting wonky job 0
Wonky job in queue, job number 0
not sleeping - this is the first job, 0
Wonky job running now
Wonky job completed with exitCode 0
Wonky job status COMPLETED 0
echo completed
echo started
Submitting wonky job 1
Wonky job in queue, job number 1
Progress:  Selecting site:1 Finished successfully:1
Submitting wonky job 2
Wonky job in queue, job number 2
Cancel called on wonky job 2
Wonky job status COMPLETED 1
Submitting wonky job 3
Wonky job in queue, job number 3
Progress:  Executing:1 Finished successfully:1
Wonky job status COMPLETED 3
Submitting wonky job 4
Wonky job in queue, job number 4
Submitting wonky job 5
Wonky job in queue, job number 5
Cancel called on wonky job 5
Wonky job status COMPLETED 4
Submitting wonky job 6
Wonky job in queue, job number 6
Submitting wonky job 7
Wonky job in queue, job number 7
Wonky job status COMPLETED 6
Wonky job status COMPLETED 7
echo failed
Execution failed:
        Submitting wonky job 8
Wonky job in queue, job number 8
Multiple mappings pointing to the same file
(localhost:062-two-in-a-row-20080522-1339-sygzk6qc/shared/062-two-in-a-row.b.out)
detected.
SWIFT RETURN CODE NON-ZERO
