[Swift-devel] proper way to run swift on resource using condor?
JP Navarro navarro at mcs.anl.gov
Wed May 21 15:06:13 CDT 2008
On May 21, 2008, at 9:48 AM, Stuart Martin wrote:
> Looking at the kit registrations for remote compute kits, purdue has
> WS GRAM (version 4.0.1 very old) registered.  But maybe it is not
> running.  Seems the kit registration should only say a version.
> Then the actual contact information (host:port/service path) should
> be only be listed when the container is up running.  I think JP has
> made the latest remote compute kit available that includes WS GRAM
> from 4.0.7 + an rft patch.  So we should ask Purdue to install
> that.  Does that make sense JP?
Kit service information is not how we communicate transient up/down
status.
We have the Inca system for that. Part of the kit registration
information
is a StatusURL that will take you to an Inca page that does show the
current
monitored status of each service in the kit.
I would expect Purdue plans to deploy the new 4.0.7 services, but it
wouldn't
hurt to let them know that you'd like for them to do so.
> http://info.teragrid.org:8080/webmds/webmds?info=tgislocal&xsl=kitsregistration
> Name	Type	Version	Endpoint
> prews-gram-condor	prews-gram	4.0.1	tg-condor.purdue.teragrid.org:
> 2119/jobmanager-condor
> globus-mds	globus-mds4	4.0.1	https://tg-condor.purdue.teragrid.org:8443/wsrf/services/DefaultIndexService
> ws-delegation	ws-delegation	4.0.1	https://tg-condor.purdue.teragrid.org:8443/wsrf/services/DelegationService
> ws-gram/Condor	ws-gram	4.0.1	https://tg-condor.purdue.teragrid.org:8443/wsrf/services/ManagedJobFactoryService
> globus-mds-auth	globus-mds4	4.0.1	https://tg-condor.purdue.teragrid.org:8448/wsrf/services/DefaultIndexService
> ws-gram/Fork	ws-gram	4.0.1	https://tg-condor.purdue.teragrid.org:8443/wsrf/services/ManagedJobFactoryService
> prews-gram-fork	prews-gram	4.0.1	tg-condor.purdue.teragrid.org:2119/
> jobmanager-fork
> On May 21, 2008, at May 21, 5:54 AM, Ben Clifford wrote:
>> You should be able to use GRAM2 for this, using the details on here:
>> http://www.teragrid.org/userinfo/hardware/resources.php?type=compute&select=single&id=16
>> or here:
>> http://www.teragrid.org/userinfo/jobs/gram.php
>> However, it appears to not work at the moment (either with Swift or
>> with a
>> simple commandline submission globus-job-run
>> tg-condor.purdue.teragrid.org/jobmanager-fork /bin/hostname)
>> I'll poke the teragrid helpdesk and CC you.
>> Swift-devel mailing list
>> Swift-devel at ci.uchicago.edu
>> http://mail.ci.uchicago.edu/mailman/listinfo/swift-devel
