[Swift-devel] gram4 detecting own host identity
    Mihael Hategan
    hategan at mcs.anl.gov
    Mon May 19 17:30:34 CDT 2008
My bad. JGlobus looks at it's own hostname property, not the system
property. Fixed in cog r2023.
Unfortunately, jglobus also resolves it before building the gass server
url. One possible "solution" there is to set the org.globus.ip system
property with the hostname. That does not get resolved, but it's
hackish.
On Mon, 2008-05-19 at 22:02 +0000, Ben Clifford wrote:
> On Mon, 19 May 2008, Mihael Hategan wrote:
> > can you dump the java command line and send it?
> java
> -Djava.endorsed.dirs=/Users/benc/work/cog/modules/vdsk/dist/vdsk-svn/bin/../lib/endorsed
> -DUID=501 -Dhostname=soju.hawaga.org.uk
> -DCOG_INSTALL_PATH=/Users/benc/work/cog/modules/vdsk/dist/vdsk-svn/bin/..
> -Dvds.home=/Users/benc/work/cog/modules/vdsk/dist/vdsk-svn/bin/..
> -Dswift.home=/Users/benc/work/cog/modules/vdsk/dist/vdsk-svn/bin/..
> -Djava.security.egd=file:///dev/urandom -classpath
> /Users/benc/work/cog/modules/vdsk/dist/vdsk-svn/bin/../etc:/Users/benc/work/cog/modules/vdsk/dist/vdsk-svn/bin/../libexec:/Users/benc/work/cog/modules/vdsk/dist/vdsk-svn/bin/../lib/addressing-1.0.jar:/Users/benc/work/cog/modules/vdsk/dist/vdsk-svn/bin/../lib/ant.jar:/Users/benc/work/cog/modules/vdsk/dist/vdsk-svn/bin/../lib/antlr-2.7.5.jar:/Users/benc/work/cog/modules/vdsk/dist/vdsk-svn/bin/../lib/axis-url.jar:/Users/benc/work/cog/modules/vdsk/dist/vdsk-svn/bin/../lib/axis.jar:/Users/benc/work/cog/modules/vdsk/dist/vdsk-svn/bin/../lib/backport-util-concurrent.jar:/Users/benc/work/cog/modules/vdsk/dist/vdsk-svn/bin/../lib/castor-0.9.6.jar:/Users/benc/work/cog/modules/vdsk/dist/vdsk-svn/bin/../lib/cog-abstraction-common-2.2.jar:/Users/benc/work/cog/modules/vdsk/dist/vdsk-svn/bin/../lib/cog-axis.jar:/Users/benc/work/cog/modules/vdsk/dist/vdsk-svn/bin/../lib/cog-grapheditor-0.47.jar:/Users/benc/work/cog/modules/vdsk/dist/vdsk-svn/bin/../lib/cog-jglobus-dev-080222.jar:/Users/ben
 c!
>  /work/cog/modules/vdsk/dist/vdsk-svn/bin/../lib/cog-karajan-0.36-dev.jar:/Users/benc/work/cog/modules/vdsk/dist/vdsk-svn/bin/../lib/cog-provider-clref-gt4_0_0.jar:/Users/benc/work/cog/modules/vdsk/dist/vdsk-svn/bin/../lib/cog-provider-condor-2.0.jar:/Users/benc/work/cog/modules/vdsk/dist/vdsk-svn/bin/../lib/cog-provider-dcache-0.1.jar:/Users/benc/work/cog/modules/vdsk/dist/vdsk-svn/bin/../lib/cog-provider-gt2-2.3.jar:/Users/benc/work/cog/modules/vdsk/dist/vdsk-svn/bin/../lib/cog-provider-gt4_0_0-2.4.jar:/Users/benc/work/cog/modules/vdsk/dist/vdsk-svn/bin/../lib/cog-provider-local-2.1.jar:/Users/benc/work/cog/modules/vdsk/dist/vdsk-svn/bin/../lib/cog-provider-localscheduler-0.2.jar:/Users/benc/work/cog/modules/vdsk/dist/vdsk-svn/bin/../lib/cog-provider-ssh-2.3.jar:/Users/benc/work/cog/modules/vdsk/dist/vdsk-svn/bin/../lib/cog-provider-webdav-2.1.jar:/Users/benc/work/cog/modules/vdsk/dist/vdsk-svn/bin/../lib/cog-resources-1.0.jar:/Users/benc/work/cog/modules/vdsk/dist/vdsk-s
 v!
>  n/bin/../lib/cog-trap-1.0.jar:/Users/benc/work/cog/modules/vds!
>  k/dist/v
> dsk-svn/bin/../lib/cog-url.jar:/Users/benc/work/cog/modules/vdsk/dist/vdsk-svn/bin/../lib/cog-util-0.92.jar:/Users/benc/work/cog/modules/vdsk/dist/vdsk-svn/bin/../lib/cog-vdsk-svn.jar:/Users/benc/work/cog/modules/vdsk/dist/vdsk-svn/bin/../lib/commonj.jar:/Users/benc/work/cog/modules/vdsk/dist/vdsk-svn/bin/../lib/commons-beanutils.jar:/Users/benc/work/cog/modules/vdsk/dist/vdsk-svn/bin/../lib/commons-collections-3.0.jar:/Users/benc/work/cog/modules/vdsk/dist/vdsk-svn/bin/../lib/commons-digester.jar:/Users/benc/work/cog/modules/vdsk/dist/vdsk-svn/bin/../lib/commons-discovery.jar:/Users/benc/work/cog/modules/vdsk/dist/vdsk-svn/bin/../lib/commons-httpclient.jar:/Users/benc/work/cog/modules/vdsk/dist/vdsk-svn/bin/../lib/commons-logging-1.1.jar:/Users/benc/work/cog/modules/vdsk/dist/vdsk-svn/bin/../lib/concurrent.jar:/Users/benc/work/cog/modules/vdsk/dist/vdsk-svn/bin/../lib/cryptix-asn1.jar:/Users/benc/work/cog/modules/vdsk/dist/vdsk-svn/bin/../lib/cryptix.jar:/Users/benc/work/c
 o!
>  g/modules/vdsk/dist/vdsk-svn/bin/../lib/cryptix32.jar:/Users/benc/work/cog/modules/vdsk/dist/vdsk-svn/bin/../lib/globus_delegation_service.jar:/Users/benc/work/cog/modules/vdsk/dist/vdsk-svn/bin/../lib/globus_delegation_stubs.jar:/Users/benc/work/cog/modules/vdsk/dist/vdsk-svn/bin/../lib/globus_wsrf_mds_aggregator_stubs.jar:/Users/benc/work/cog/modules/vdsk/dist/vdsk-svn/bin/../lib/globus_wsrf_rendezvous_service.jar:/Users/benc/work/cog/modules/vdsk/dist/vdsk-svn/bin/../lib/globus_wsrf_rendezvous_stubs.jar:/Users/benc/work/cog/modules/vdsk/dist/vdsk-svn/bin/../lib/globus_wsrf_rft_stubs.jar:/Users/benc/work/cog/modules/vdsk/dist/vdsk-svn/bin/../lib/gram-client.jar:/Users/benc/work/cog/modules/vdsk/dist/vdsk-svn/bin/../lib/gram-stubs.jar:/Users/benc/work/cog/modules/vdsk/dist/vdsk-svn/bin/../lib/gram-utils.jar:/Users/benc/work/cog/modules/vdsk/dist/vdsk-svn/bin/../lib/gvds.jar:/Users/benc/work/cog/modules/vdsk/dist/vdsk-svn/bin/../lib/j2ssh-common-0.2.2.jar:/Users/benc/work/
 c!
>  og/modules/vdsk/dist/vdsk-svn/bin/../lib/j2ssh-core-0.2.2-patc!
>  hed.jar:
> /Users/benc/work/cog/modules/vdsk/dist/vdsk-svn/bin/../lib/jakarta-regexp-1.2.jar:/Users/benc/work/cog/modules/vdsk/dist/vdsk-svn/bin/../lib/jakarta-slide-webdavlib-2.0.jar:/Users/benc/work/cog/modules/vdsk/dist/vdsk-svn/bin/../lib/jaxrpc.jar:/Users/benc/work/cog/modules/vdsk/dist/vdsk-svn/bin/../lib/jce-jdk13-131.jar:/Users/benc/work/cog/modules/vdsk/dist/vdsk-svn/bin/../lib/jgss.jar:/Users/benc/work/cog/modules/vdsk/dist/vdsk-svn/bin/../lib/jsr173_1.0_api.jar:/Users/benc/work/cog/modules/vdsk/dist/vdsk-svn/bin/../lib/jug-lgpl-2.0.0.jar:/Users/benc/work/cog/modules/vdsk/dist/vdsk-svn/bin/../lib/junit.jar:/Users/benc/work/cog/modules/vdsk/dist/vdsk-svn/bin/../lib/log4j-1.2.8.jar:/Users/benc/work/cog/modules/vdsk/dist/vdsk-svn/bin/../lib/naming-common.jar:/Users/benc/work/cog/modules/vdsk/dist/vdsk-svn/bin/../lib/naming-factory.jar:/Users/benc/work/cog/modules/vdsk/dist/vdsk-svn/bin/../lib/naming-java.jar:/Users/benc/work/cog/modules/vdsk/dist/vdsk-svn/bin/../lib/naming-reso
 u!
>  rces.jar:/Users/benc/work/cog/modules/vdsk/dist/vdsk-svn/bin/../lib/opensaml.jar:/Users/benc/work/cog/modules/vdsk/dist/vdsk-svn/bin/../lib/puretls.jar:/Users/benc/work/cog/modules/vdsk/dist/vdsk-svn/bin/../lib/resolver.jar:/Users/benc/work/cog/modules/vdsk/dist/vdsk-svn/bin/../lib/saaj.jar:/Users/benc/work/cog/modules/vdsk/dist/vdsk-svn/bin/../lib/stringtemplate.jar:/Users/benc/work/cog/modules/vdsk/dist/vdsk-svn/bin/../lib/vdldefinitions.jar:/Users/benc/work/cog/modules/vdsk/dist/vdsk-svn/bin/../lib/wsdl4j.jar:/Users/benc/work/cog/modules/vdsk/dist/vdsk-svn/bin/../lib/wsrf_core.jar:/Users/benc/work/cog/modules/vdsk/dist/vdsk-svn/bin/../lib/wsrf_core_stubs.jar:/Users/benc/work/cog/modules/vdsk/dist/vdsk-svn/bin/../lib/wsrf_mds_index_stubs.jar:/Users/benc/work/cog/modules/vdsk/dist/vdsk-svn/bin/../lib/wsrf_mds_usefulrp_schema_stubs.jar:/Users/benc/work/cog/modules/vdsk/dist/vdsk-svn/bin/../lib/wsrf_provider_jce.jar:/Users/benc/work/cog/modules/vdsk/dist/vdsk-svn/bin/../lib
>  wsrf_tools.jar:/Users/benc/work/cog/modules/vdsk/dist/vdsk-svn!
>  /bin/../
> lib/wss4j.jar:/Users/benc/work/cog/modules/vdsk/dist/vdsk-svn/bin/../lib/xalan.jar:/Users/benc/work/cog/modules/vdsk/dist/vdsk-svn/bin/../lib/xbean.jar:/Users/benc/work/cog/modules/vdsk/dist/vdsk-svn/bin/../lib/xbean_xpath.jar:/Users/benc/work/cog/modules/vdsk/dist/vdsk-svn/bin/../lib/xercesImpl.jar:/Users/benc/work/cog/modules/vdsk/dist/vdsk-svn/bin/../lib/xml-apis.jar:/Users/benc/work/cog/modules/vdsk/dist/vdsk-svn/bin/../lib/xmlsec.jar:/Users/benc/work/cog/modules/vdsk/dist/vdsk-svn/bin/../lib/xpp3-1.1.3.4d_b4_min.jar:/Users/benc/work/cog/modules/vdsk/dist/vdsk-svn/bin/../lib/xstream-1.1.1-patched.jar:
> org.griphyn.vdl.karajan.Loader '-sites.file'
> '../sites/tguc-fork-gram4.xml' '-tc.file' 'tmp.tc.data.sites'
> '061-cattwo.swift'
