[Swift-devel] [Bug 107] restarts broken (by generalisation of data	file handling)
    bugzilla-daemon at mcs.anl.gov
    Mon May 19 10:06:11 CDT 2008
http://bugzilla.mcs.anl.gov/swift/show_bug.cgi?id=107
benc at hawaga.org.uk changed:
           What    |Removed                     |Added
                 CC|                            |skenny at uchicago.edu, swift-
                   |                            |devel at ci.uchicago.edu
------- Comment #4 from benc at hawaga.org.uk  2008-05-19 10:05 -------
r1982 introduces another restart test, tests/misc/restart2.sh
This test does not pass, so I have not put it in the automatic runs. It can be
run by calling ./restart2.sh from the tests/misc/ directory.
Superficially what appears to cause a problem is when a file is mapped inside a
procedure; so then multiple data sets have the same variable name (one per
invocation of that procedure); and then on restart, the fact that any
invocation of that procedure has completed and successfully produced output for
that variable means that all invocations of that procedure are treated as
successfully completed.
Configure bugmail: http://bugzilla.mcs.anl.gov/swift/userprefs.cgi?tab=email
------- You are receiving this mail because: -------
You are on the CC list for the bug, or are watching someone who is.
