[Swift-devel] gram4 detecting own host identity
Ben Clifford
benc at hawaga.org.uk
Mon May 19 07:16:14 CDT 2008
On Mon, 19 May 2008, Ben Clifford wrote:
> then GLOBUS_HOSTNAME=HOSTNAME
> In the four machines I just looked at, that gives the correct globally
> unique name.
I found another that it is not set correctly on.
However, if this is a better way to do it on average than Java can do in
real life deployments, then it is probably what should happen.
