[Swift-devel] coaster / Bad file descriptor
    Ben Clifford
    benc at hawaga.org.uk
    Wed May 14 06:40:17 CDT 2008
Here's an error I haven't seen before.
This is trying to run coasters with
tests/sites/coaster/tgncsa-hg-coaster-pbs-gram2.xml
The first bit of the outputting trace is here:
Execution failed:
        Cannot submit job: Bad file descriptor
org.globus.cog.abstraction.impl.common.task.TaskSubmissionException:
        at
org.globus.cog.abstraction.impl.scheduler.pbs.execution.JobSubmissionTaskHandler.submit(JobSubmissionTaskHandler.java:75)
I put the log file at
http://www.ci.uchicago.edu/~benc/tmp/bad-fd-061-cattwo-20080514-1231-7uzfzn8b.log
This is using gt2:pbs (so should be using PBS local submission on the head
node).
I get the same error three times in a row (this site definition has never
worked, for one reason or another).
This same build can run the site tests ok to fletch using gt2:gt2,
tests/sites/coaster/fletch-coaster-condor-gram2.xml.
