[Swift-devel] tests/sites/
Ben Clifford
benc at hawaga.org.uk
Wed May 7 19:31:26 CDT 2008
I just did some reconfiguration of the tests/sites/ site tests (in r1940),
so that any swift developer who has access to OSG and CI resources and
TeraGrid DAC TG-CCR080002N (the Swift development DAC) should be able to
run them.
In practice that means me and mihael, rather than just me.
What I did was make mode +t working directories on each site, usually
under my home directory, and set each site test to point there.
So to run:
1. put the Swift to be tested on your path
2. make a proxy
3. cd tests/sites
4. ./run-all
5. go for a two hour hike or otherwise occupy self
6. return to find list of sites which failed on stdout, at end of run.
At the moment, it doesn't keep logs for sites because of the way it uses
the other bits of the test suite, but you can run an individual site by
typing:
./run-site tguc-fork-gram4.xml (for example)
which will leave all the logs in ../language-behaviour/
