[Swift-devel] Why build prompts in redist?
    Michael Wilde
    wilde at mcs.anl.gov
    Mon Mar 24 19:30:14 CDT 2008
It was - thanks. I missed Ben's initial note "As of r1738 (to
provider-deef)". That fixed it.
- Mike
On 3/24/08 5:22 PM, Mihael Hategan wrote:
> However, given that Ben removed that warning entirely, causes me to
> believe that your provider-deef isn't up to date.
> On Mon, 2008-03-24 at 17:20 -0500, Mihael Hategan wrote:
>> Seems quite obvious, given that the warning was meant to deal with a
>> situation where one would build provider-deef after building swift,
>> whereas the -Dwith-provider-swift trick does precisely the opposite.
>> On Mon, 2008-03-24 at 17:13 -0500, Michael Wilde wrote:
>>> I just updated to 1756 and I still get same prompt. This is not a big
>>> deal, just thought you'd want to know.
>>> My command was:
>>>    ant -Dwith-provider-deef redist
>>> in cog/modules/vdsk
>>> - Mike
>>> dist.dir.warning:
>>>      [input]
>>>      [input]
>>>      [input] Warning! The specified target directory
>>> (/radix-homes01/wilde/swift/src/cog/modules/vdsk/../..//modules/vdsk/dist/vdsk-svn)
>>> does not seem to contain a Swift build.
>>>      [input] Press Return to continue with the build or CTRL+C to abort...
>>>      [input]
>>>      [input]
>>>> As of r1738 (to provider-deef) this does not happen any more.
>>> _______________________________________________
>>> Swift-devel mailing list
>>> Swift-devel at ci.uchicago.edu
>>> http://mail.ci.uchicago.edu/mailman/listinfo/swift-devel
