[Swift-devel] Re: swift-falkon problem
    Michael Wilde
    wilde at mcs.anl.gov
    Mon Mar 24 10:05:16 CDT 2008
On 3/24/08 9:47 AM, Ioan Raicu wrote:
>>> Looking at the Falkon logs might reveal more about if the plateau was
>>> due to Falkon or not.  Where would I find the Falkon logs that
>>> correlate to these graphs?
>> bblogin.mcs.anl.gov:/home/wilde/falkon/logs
> But which ones, there are about 8 dirs (or something similar), there,
> and each dir contains multiple runs... how can I tell which log, and
> which parts of the logs are the run that is graphed by Ben?
The pointer to that was in this email:
On 3/24/08 7:55 AM, Michael Wilde wrote:
 > The summary logs are on bblogin in ~wilde/falkon.
 > I keep swift run logs in ~wilde/swift/logs/runNNN and copy some of them
 > to the CI NFS at ~benc/swift-logs/wilde/runNNN.
 > I'll start copying the falkon logs to the same place, but for the
 > previous tests you'll need to locate them separately.
 > In the swift log dirs, amps*.log shows the run time (look at first and
 > last line).  Ben pointed out that I'm doing data transfer throttling
 > which is slowing things down. I did that intentionally at this stage to
 > avoid hurting sico NFS. I'll start opening that throttle up.
