[Swift-devel] Excessive object-closing messages in log
Michael Wilde
wilde at mcs.anl.gov
Sun Mar 23 22:15:10 CDT 2008
Ben, for a small swift script that iterates over a parameter array, I
seem to be getting about (N^2)/2 log records regarding object closing.
The messages are of the form:
2008-03-23 18:30:36,877-0600 INFO CloseDataset
org.griphyn.vdl.mapping.RootDataNode identifier
tag:benc at ci.uchicago.edu,2008:swift:dataset:20080323-1828-x14dlldb:720000003246
with no value at dataset=ofile (closed)
For 500 entries, I had about 130K object closing log records; for 1000
entries, over 500K:
bb$ grep -i -c closedataset run{341,342}/amps*.log
run341/amps1-20080323-1828-25xcue89.log:130259
run342/amps1-20080323-1935-su38n0k5.log:510509
341 is 500 jobs, 342 is 1000 jobs.
Is this log mechanism supposed to do that? If so, is that practical, as
we want to test this script in the range of 1M jobs.
run342 is in swift-logs/wilde
The script is below.
My properties are:
sitedir.keep=true
lazy.errors=true
execution.retries=0
#kickstart.always.transfer=true
throttle.submit=off
throttle.host.submit=off
throttle.transfers=20
throttle.file.operations=20
throttle.score.job.factor=1000000
sitedir.keep=true
- Mike
type amout;
(amout ofile ) runam3 (string id , string dieselLowSLightLLProd, string
dieselMedSLightLLProd)
app { runam3 id dieselLowSLightLLProd dieselMedSLightLLProd ; }
type params {
string id;
string dieselLowSLightLLProd;
string dieselMedSLightLLProd;
doall(params p[])
foreach pset in p {
amout ofile <single_file_mapper; file=@strcat("amdi.",pset.id)>;
ofile = runam3(pset.id, pset.dieselLowSLightLLProd,
pset.dieselMedSLightLLProd);
// Main
params p[];
p = readdata("paramlist");
doall(p);
