[Swift-devel] Re: swift-falkon problem
Zhao Zhang zhaozhang at uchicago.edu
Mon Mar 17 15:34:06 CDT 2008
yep, the swift option only cares about "chdir". I am not sure that I
have the SVN permissions to commit. That will be great, if you commit
this to the SVN. :-)
zhao
Ioan Raicu wrote:
> What does the last option "swift" really do?  Is that the chdir?  If
> yes, then it should be a default behavior (rather than an option) as
> long as the directory field is specified.  Do you have SVN permissions
> to commit changes?  If yes, you should commit this.  If not, I'll
> commit it, and you need to get the permissions to commit code to the
> Falkon SVN (I'll work on this).
> Ioan
> Zhao Zhang wrote:
>> Hi,
>> The attachment is the BGexec source code to use with both non-swift
>> and swift. To use it, first compile it like "gcc -o BGexec BGexec.c",
>> run invoke it, run "./BGexec 127.0.0.1 55000 55001 -debug swift" the
>> last option is to indicate that we are running BGexec with swift, if
>> not simply change it to no.
>> zhao
>> Michael Wilde wrote:
>>> Sorry - another mis-diagnosis and incorrect conclusion on my part.
>>> Zhao just told me that we have out of date falkon worker code on the
>>> sicortex that is not chdir'ing to the cwd arg of the falkon request.
>>> That explains what Im seeing. Its being fixed now and checked in.
>>> To answer your questions though:
>>> Im running swift on a linux box bblogin.mcs.anl.gov
>>> It mounts the sicortex under /sicortex-homes
>>> I run swift from /sicortex-homes/wilde/amiga/run
>>> My sites file says:
>>> <pool handle="sico">
>>>       <gridftp  url="local://localhost"/>
>>>       <execution provider="deef"
>>> url="http://140.221.37.30:50001/wsrf/services/GenericPortal/core/WS/GPFactoryService"/>
>>>       <workdirectory>/home/wilde/swiftwork</workdirectory>
>>> </pool>
>>> and /home/wilde/swiftwork on bblogin is a symlink to
>>> /sicortex-homes/wilde/swiftwork
>>> so that when swift writes files to the sicortex dir (eg when it
>>> creates shared/*) its using the same pathname that the worker-side
>>> will use when the job runs.  Ie, even though the mount-points differ
>>> between the swift host and the worker host, symlinks make the
>>> workdir appear under same name on both sides.
>>> If NFS adheres to its close-to-open-coherence semantics, this then
>>> should I think work.
>>> My scp-provider question is probably still worth answering and
>>> trying if this doesnt work.
>>> - Mike
>>> On 3/17/08 2:57 PM, Ben Clifford wrote:
>>>> what does your filesystem layout look like?
>>>> Where are you running swift? And where are you putting your
>>>> scicortex site directory? On an NFS that is also accessible from
>>>> your submit machine? If so, what path?
