[Swift-devel] more ftp errors running terminable->tg uc
    Ben Clifford
    benc at hawaga.org.uk
    Wed Mar 12 23:40:52 CDT 2008
In addition to the mlst error reporting in the thread 'stageout: Expected
multiline reply', today I see a similar-but-different error with other
swift configurations running on terminable going to TG UC. The below
occurs when I try PBS+GRAM4, fork+gram4, fork+gram2 (with the mlst error
occuring with pbs+gram2 as before).
I do not get this behaviour submitting from terminable to TeraPort. I do
get it submitting to the OSG site UCLA_Saxon_Tier3.
This is all running the test 130-fmri, which has in the past managed to
trigger a bunch of race conditions that the other tests haven't. In
general the other test I've been running, 061-cattwo, has been working
mostly ok.
The specific configurations that I use are in the svn in
vdsks/tests/sites/
Server refused performing the request. Custom message:  (error code 1)
[Nested exception message:  Custom message: Unexpected reply: 451 ocurred
during retrieve()
org.globus.ftp.exception.DataChannelException: setPassive() must match
store() and setActive() - retrieve()  (error code 2)
        at
org.globus.ftp.extended.GridFTPServerFacade.retrieve(GridFTPServerFacade.java:469)
        at org.globus.ftp.FTPClient.put(FTPClient.java:1289)
        at
org.globus.cog.abstraction.impl.file.gridftp.old.FileResourceImpl.putFile(FileResourceImpl.java:399)
        at
org.globus.cog.abstraction.impl.fileTransfer.DelegatedFileTransferHandler.doDestination(DelegatedFileTransferHandler.java:356)
        at
org.globus.cog.abstraction.impl.fileTransfer.CachingDelegatedFileTransferHandler.doDestination(CachingDelegatedFileTransferHandler.java:47)
        at
org.globus.cog.abstraction.impl.fileTransfer.DelegatedFileTransferHandler.run(DelegatedFileTransferHandler.java:493)
        at java.lang.Thread.run(Thread.java:595)
