[Swift-devel] Re: Question of wrapper.sh
    Zhao Zhang
    zhaozhang at uchicago.edu
    Sat Mar  8 17:50:19 CST 2008
Hi, All
It is ok now, I solve that problem. It is a simple typo error in the
GPfactoryservice path. Now swift could send task directly to falkon.
Then I submit 100 sleep 0 tasks from swift to falkon. It tool 50 seconds
from the falkon's point of view to complete these tasks.
The info.tar file is the info files for these 100 sleep jobs.and the
stdout.txt is that I get from the standard output from swift.
Thanks again for your help.
zhao
Ben Clifford wrote:
> On Fri, 7 Mar 2008, Zhao Zhang wrote:
>> Hi, Ben
>> There is nothing in the sleep-20080307-1808-ik0izkmg.d directory, and also
>> nothing in rlog file. When I could run it through falkon before, it still has
>> that socket error, it is ok, swift will use another port.
> You should get something in the .log file, though. Please send that.
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/swift-devel/attachments/20080308/bdddbf36/attachment.obj>
An embedded and charset-unspecified text was scrubbed...
URL: <http://lists.mcs.anl.gov/pipermail/swift-devel/attachments/20080308/bdddbf36/attachment.txt>
