[Swift-devel] Re: Question of wrapper.sh
    Ioan Raicu
    iraicu at cs.uchicago.edu
    Fri Mar  7 11:16:29 CST 2008
OK, Zhao is working on it, and should get you those logs later today.
Ioan
Ben Clifford wrote:
> On Fri, 7 Mar 2008, Ioan Raicu wrote:
>> Ideally, we'd want any extra logging outside of the bare minimum to be
>> optional, something that could be turned on or off depending on output level.
>> Maybe you or Mihael could work in such an option in the future, so we could
>> easily disable all logging in the wrapper script if we need to.  In the
> You can perhaps convince me easily (or unconvince me) if you provide the
> -info files for a large test run. I implemented measurements there in
> november to provide quantified results for almost exactly this situation.
> You will considerably enhance this discourse by providing that information
> now rather than later.
Ioan Raicu
Ph.D. Candidate
Distributed Systems Laboratory
Computer Science Department
University of Chicago
1100 E. 58th Street, Ryerson Hall
Chicago, IL 60637
Email: iraicu at cs.uchicago.edu
Web:   http://www.cs.uchicago.edu/~iraicu
http://dev.globus.org/wiki/Incubator/Falkon
http://dsl-wiki.cs.uchicago.edu/index.php/Main_Page
