[Swift-devel] stageout: Expected multiline reply
    Ben Clifford
    benc at hawaga.org.uk
    Sun Mar  2 14:08:41 CST 2008
at least today its repeatable and consistent against TGUC using pbs+gram2
but doesn't happen any time I use fork+gram2.
some other sites that I've run it against haven't had this problem.
I rarely run stuff from terminable so I have no idea if this has been the
case for some time or is for one day only.
On Sun, 2 Mar 2008, Mihael Hategan wrote:
> Repeatable or not? Consistent or not?
> On Sun, 2008-03-02 at 16:56 +0000, Ben Clifford wrote:
> > Running from terminable to tg-uc, I get an error at stageout, starting
> > with the below:
> > Caused by: org.globus.ftp.exception.ServerException:  Custom message:
> > Could not
> > create MlsxEntry [Nested exception message:  Custom message: Expected
> > multiline
> > reply] [Nested exception is org.globus.ftp.exception.FTPException:  Custom
> > messa
> > ge: Expected multiline reply]
> >         at org.globus.ftp.FTPClient.mlst(FTPClient.java:642)
> >         at
> > org.globus.cog.abstraction.impl.file.gridftp.FileResourceImpl.isDirec
> > tory(FileResourceImpl.java:159)
> > The complete log file is
> > http://www.ci.uchicago.edu/~benc/tmp/061-cattwo-20080302-1031-vdualzq0.log
> > This is with 0.4rc1. This is using gram2 to submit to PBS. Other runs from
> > my testing appeared to have worked ok submitting to fork. I'll dig a bit
> > deeper, but I'm not sure what the likely meaning of the above error is.
