[Swift-devel] Falkon and Coaster support for MPI
    Benoit Roux
    roux at uchicago.edu
    Sun Jun 29 16:17:13 CDT 2008
On Jun 29, 2008, at 4:07 PM, Michael Wilde wrote:
> Ben,
> On 6/29/08 2:19 PM, Ben Clifford wrote:
>> On Sun, 29 Jun 2008, Michael Wilde wrote:
>>> The app that accelerated this discussion is CHARMM for molecular
>>> dynamics. CHARMM on BGP with the parameters needed in the use
>>> case in question has a long runtime on 1 CPU (24-36 hours), and
>>> seems to peak in performance using MPI at 32 CPUS. Runs >6 hours
>>> are also not runnable today on the Argonne BGP without a
>>> reservation. So the most effective way to use the BGP for some
>>> specific CHARMM runs needed by Benoit Roux's group is to run
>>> large numbers of multi-hour 32-rank MPI jobs.
>> OK.
>> This seems like an interesting application.
>> I can spend some time working on this in the next few weeks, as
>> long as you provide me with the following:
>>  i) someone who knows how the charmm applications work (eg from
>> Benoit's group)
> Wei Jiang from Benoit's group spent several hours with me Friday
> explaining how they run CHARMM.
> The approach uses scripts that Yuqing Deng, who recently left the
> group, developed.  These are on the Argonne "KBT" cluster. You
> should get on the Argonne accounts web and request access to that
> cluster, kbt.mcs.anl.gov.
> One there, you can run perl scripts that generate either shell
> scripts or pbs jobs to do a CHARMM run. It was fairly complex, and
> I need to transcribe some notes on this.
> Benoit was going to try to locate slides and/or docs from a talk
> that Yuqing gave before he left, on how to run his tools.
> Ray Loy of the ALCF team is working on compiling a non-MPI CHARMM
> runnable under ZeptoOS on the BGP, and he also wanted to try HTC mode.
Note that a non-MPI CHARMM job on BG would be not super fast, and MPI
capability would be desirable.
> Nika's latest workflows running CHARMM are also a good reference
> point.
> Wei can provide info on how to do a sample run from Yuquing's scripts.
>>  ii) someone who knows how MPI works on the BG/P (maybe Kamil?)
> MPI on BGP under ZeptoOS is still several weeks away from friendly-
> user testing capability. Kamil and Kaz (and Pete Beckman) are the
> Argonne ZeptoOS team. Kaz is working on ZeptoOS MPI and just
> reached hello-world about a week ago.
> - Mike
URL: <http://lists.mcs.anl.gov/pipermail/swift-devel/attachments/20080629/4fa4e7d5/attachment.html>
