[Swift-devel] Falkon and Coaster support for MPI
Ioan Raicu iraicu at cs.uchicago.edu
Sun Jun 29 14:25:38 CDT 2008
How do you guarantee that N nodes will all start at the same time?  At
least, in Falkon, this is the largest problem that I am not sure how to
address... the Falkon scheduler doesn't know how to handle a task of N
processors, it only knows tasks of 1 processor...
Lets take an example.  Assume you have 256 CPUs free.  Lets say you get
a MPI job for 32 CPUs, the new improved scheduler could simply replicate
that single CPU task 32 times, and start the task on 32 CPUs.  Now,
while the 32 CPU MPI job is running, a 256 CPU MPI job comes in, and
needs to be scheduled.  The naive replication of 1 ==> 256 tasks doesn't
work anymore, as there are no 256 CPUs free, only 224 are free.  So, the
scheduler needs to be smart enough to wait for this 32 CPU MPI job to
finish, before it can launch the 256 CPU job, and make sure no other job
will go through before that might use up any of the free CPUs.  All this
is certainly do-able, as PBS, SGE, Condor, etc... most LRMs can deal
with MPI jobs just fine, but its certainly not a trivial addition to
Falkon, and its not clear to me how easy or hard it would be in Coaster
either, depending on how much effort is placed in the scheduler that
feeds jobs to Coaster.
Ioan
Ben Clifford wrote:
> I had a brief look at how MPI runs inside PBS.
> It looks something like:
>  1.   user requests n nodes to run on PBS
>  2.   PBS allocates those n nodes, and writes a description of them all
>       into a per-job (not per-node) $PBSNODEFILE
>  3.   PBS runs the same mpi command-line on all of the nodes, specifying
>          $PBSNODEFILE somewhere in that command line.
>  4.   The mpi commandline uses the $PBSNODEFILE to know how to get to all
>          the nodes.
> It might not be too much change to the coaster code to make it so you can
> get this behaviour. You'd need to be able to specify a node count (rather
> than the implicit count of 1 at the moment) and have the coaster manager
> handle starting everything up at the same time and providing something
> like $PBSNODEFILE.
Ioan Raicu
Ph.D. Candidate
Distributed Systems Laboratory
Computer Science Department
University of Chicago
1100 E. 58th Street, Ryerson Hall
Chicago, IL 60637
Email: iraicu at cs.uchicago.edu
Web:   http://www.cs.uchicago.edu/~iraicu
http://dev.globus.org/wiki/Incubator/Falkon
http://dsl-wiki.cs.uchicago.edu/index.php/Main_Page
