[Swift-devel] workflow run with the newest Swift
    Ben Clifford
    benc at hawaga.org.uk
    Fri Jun 27 16:50:34 CDT 2008
On Fri, 27 Jun 2008, lixi at uchicago.edu wrote:
> >I think you should probably restart that run and see how it
> works.
> Yes, the new run is finished successfully. The execution
> speed for this run is good. However, a lot of "cached
> overload count = 13 just generated count = 13 (EEP!)" like
> information made the execution display on screen is not very
> friendly.
yes, that patch was intended more for discussion than real use. Mihael's
one, overload-chk2, is better.
> At the beginning, I had thought that jobs weren't
> executed. After checking the output directory and log file,
> we could only find many jobs done already.
Do you have the log file for this? I would like to see how it worked.
