[Swift-devel] Re: OSG Interest Group meeting (fwd)
    Ben Clifford
    benc at hawaga.org.uk
    Fri Jun 27 10:24:57 CDT 2008
below discussion happened in an off-list thread but it may be of interest
for archival and intra-swift communication purposes.
---------- Forwarded message ----------
Date: Fri, 27 Jun 2008 15:23:55 +0000 (GMT)
To: lixi at uchicago.edu
Cc: Michael Wilde <wilde at mcs.anl.gov>,
    Zhengxiong Hou <zhengxiongh at uchicago.edu>, Jing Tie <jtie at cs.uchicago.edu>,
    Alina Bejan <abejan at ci.uchicago.edu>, Zhao Zhang <zhaozhang at uchicago.edu>,
    Ian Foster <foster at mcs.anl.gov>, Charles Bacon <bacon at mcs.anl.gov>
Subject: Re: OSG Interest Group meeting
On Fri, 27 Jun 2008, lixi at uchicago.edu wrote:
> of whole workflow. However, it could not guarantee
> completely successful run of every workflow, because some
> sites produce shared file system error as follows:
> Application exception: No status file was found. Check the
> shared filesystem on hostname
> This is the error which I don't know how to check in advance.
The recent scoring changes should reduce the damaging effect of such sites
- Swift will make some attempts to use but should rapidly slow down
submissions.
> 2. With replication option enabled, I often
> encountered "Multiple mappings pointing to the same file"
> error which leaded to the failure of the whole workflow. I
> think that I've already reported that error. Since then, I
> didn't receive the message notifying the resolution of this
> problem. So I disabled "replication" option in recent
> experiments.
You did, though Mihael made a fix which cured my attempt at reproducing
this. (see this:
http://mail.ci.uchicago.edu/pipermail/swift-devel/2008-May/003140.html)
Please try using replication again.
Also, if you have open issues that aren't actively being addressed, please
put them in the bugzilla.
