[Swift-devel] Re: scheduler changes to deal with fast-failing sites
    Ben Clifford
    benc at hawaga.org.uk
    Thu Jun 26 08:38:48 CDT 2008
r2058 results in scheduling hangs, due to the way in which the overloaded
host count is cached and not recomputed at the appropriate time.
The attached hacky patch demonstrates a different (more correct though
less efficient) was of counting the overloaded host count.
I can reliably get a hang after about 10 minutes running:
 cd tests/language-behaviour/
 while true; do swift 0755-ext-mapper.swift ; done
which goes away with this patch.
Patch is at http://www.ci.uchicago.edu/~benc/overload-chk
