[Swift-devel] slightly easier log file report html generator command
Ben Clifford
benc at hawaga.org.uk
Sun Jun 15 07:21:32 CDT 2008
I just (r2061) put a command in the log-processing code to hopefully make
it easier to generate report webpages for Swift log files.
To use:
svn co https://svn.ci.uchicago.edu/svn/vdl2/log-processing
cd log-processing/bin
export PATH=`pwd`:$PATH
Now you will have a command swift-plot-log that you can run on a log file
like this:
$ swift-plot-log workflowtest-20080529-1145-n44o2cj1.log
You'll get lots of output, most likely with a bunch of errors because that
code is quite lame. You will also get a directory called report-<logfile>/
with an index.html in it. Open that with your favourite web browser.
For example, on os x:
$ open report-workflowtest-20080529-1145-n44o2cj1/index.html
Eventually I'd like to move all of this into the main release rather than
it being a separate checkout. But not yet.
